car runs for 5 seconds
Old Jun 18, 2012 | 08:21 AM
Sam Mohammed Aleyadeh's Avatar
Default car runs for 5 seconds
Hello everyone
I have a bit of a problem I asked the dealership and they cant find the problem with My car
it started to turn off at random time that began to shrink in size from 1 hour to 30 mins to 5 mins now it will only run for 5 seconds and then turns off I had recently put the fuel pump from a 2007 S60 Volvo so i doubt that's the problem i checked the injectors and they seem to be clean sealed and in a good shape I would appreciate any ideas
some times the check engine light flashes a little then goes away and the message reduced engine performance comes up.
thanks in advance
Old Jun 18, 2012 | 09:47 PM
Nichals's Avatar
a vac leak that's getting progressively worse, likely around your intake manifold where it bolts to the head.
re-torque the bolts and see if it gets better, if it does remove the manifold and replace your gasket.
that's my guess
Old Jun 20, 2012 | 01:14 AM
that's my guess
thanks for the advice it turned out the problem was with the vac tube itself the restraint has shifting causing a leak thanks again
southislander
Volvo C30
Mar 4, 2015 03:38 PM
johnb317
May 13, 2013 12:43 PM
dman777
Jun 22, 2012 10:21 PM
ibified
Oct 2, 2011 07:04 PM
dbehr
Sep 30, 2004 09:46 AM
