Car Shake And Ac Noise For Help
Hi all, I have a 2002 S60 2.4T with nearly 102k miles. Now there are two problems trouble me for several months.
1) Car shake when accelerate around 60mph. The shake just happened around 60mph, from 57mph to 65mph. Accelerate below 55mph or above 65mph will not cause a shake and it runs smoothly. I did a alignment one month ago, it was a little better but this situation is still there and getting worse. To solve this problem, I replaced the control arms. But no better.
2) An intermittent noise in front of the passenger side when AC is on, no matter cold or warm. The clicking noise sounds like the wind is blowing something and only happen when the AC is on low level and the car is parking or in a low speed. The noise will fall off a little bit when an acceleration made or the car went through a bumper, sometimes it won't happen in the whole run.
Any suggestion for these problems? Thank you all!
I will brought my car to a Volvo Independent this week. Hope they can find out what the problem is.
Here is the update 05/13/11.
I brought my car to a Volvo Independent in my area this week. Their mechanic told me they believe the shake is caused by one or both of my drive axles. And they thought that the noise comes from blower motor.
To solve the noise problem, they suggest me to replace the blower motor and the blower resistor with $650 parts and labor.
To replace both axles they want to charge me $130 for each axle and $230 for labor.
They also doubt the vibration may caused by internal of transmission but need to replace axles first to see if that will fix the problem.
Well, I think the noise from blower motor make sense. But do I really need to replace both blower motor and the resistor? How much labor might it be?
Interestingly, I bought drive axles and brought the car to another auto maintenance (not a Volvo Independent), they did a test drive, checked the axles and told me the axles are totally fine. They did not want to waste my money on axles.
Now I got confused, what on earth leads my car shaking? I've already replaced my control arms and Ball Joints. Do I need to check the tie rod ends? Is there any other reason for the vibration?
To be continued...
To be continued...
"To solve the noise problem, they suggest me to replace the blower motor and the blower resistor with $650 parts and labor.
To replace both axles they want to charge me $130 for each axle and $230 for labor."
99% of dealerships will tell you a part needs replaced, that is where they get the most revenue.
I brought my car to a Volvo Independent in my area this week. Their mechanic told me they believe the shake is caused by one or both of my drive axles. .... To replace both axles they want to charge me $130 for each axle and $230 for labor.
To be continued...
To be continued...
Good luck.
2001 S60 Car Shake on Acceleration
Our 2001 s60 also shakes on acceleration at exactly the same speeds described about 95 up to 105 km/hr (around 60 mph). It only shakes on acceleration. But does not shake on acceleration at lower speeds or at higher speeds. We had the wheels balanced and aligned. The mechanic said they had only been slightly out, but it fixed the problem. This was less than 6 months ago, and the shake is back again. We will try another wheel alignment/balancing, but what a pain and expense to do this every few months!
Thanks, I've already replaced both axles. Now the high speed shake disappear.
But I noticed that there is a slightly shake happen during 25~35mph.
Maybe this time I need to do a tire balance?
The vibration is caused by the right axle shaft and you should replace it as soon as possible or you will fece replacing engine mounts as well. I would check the top mount for wear anyways. Axle shafts on this car go around 100k mile mark and you can't really tell by just looking at it, as there is no excessive play or sound when turning (classic wear signs).
Good luck.
Good luck.
Good luck.
Good luck.
Why Do you say the The Right Side only?
#17
#18
#20
Having a similar issue with the car vibrating/shaking only while actually accelerating starting between 60 and 70 mph. I'm a little confused about it because my check engine light came on just about when started happening. I had a code ran and its p2402 (generic OBD II)...which is an "emission system leak circuit pressure high" issue...so I wondered if my car is missing or being starved of fuel or oxygen when I get to that speed...however, (and this may be obvious to some) I DO also need my right axle replaced which is why I am on this thread and why I joined the forum...I noticed the boot broken a couple months ago and am starting to hear the little pop/click when shifting into gear or sometimes when just accelerating from a stop. So, I'm ordering the axle and will replace it...but want some other opinions....is it possible the motor is causing the shaking?
