Changing Radiator
Yes, it can if you do it this way you will need to jack up the car and I recommend having an assistant for the extra eyes as well as the hands. It will come out as a "sandwich" with the condenser and the intercooler (If you have a turbo). I just did this two weeks ago with my wifes help. Good luck!
Thank you for your replies... So I installed the radiator and now the car won't turn over.. it seems like its not getting gas . I changed the battery on it because it died out on me. I put a voltage meter to it and it was 4 voltage. So I put a new one. The car cranks but does not turn over. Also how do I replace the ATF .. thank you guys..
