CHECK ENGINE LIGHT
Old Mar 4, 2008 | 12:54 PM
Capo Cam's Avatar
Default CHECK ENGINE LIGHT
MY CHECK ENGINE LIGHT STAYS ON ALL THE TIME. I ASSUME WITH 230K MILES THIS WOULD BE EXPECTED OR SHOULD I BE WORRIED?
Old Mar 4, 2008 | 01:29 PM
65mustang's Avatar
Default RE: CHECK ENGINE LIGHT
I believe you should get the codes pulled and see what is wrong. It shouldn't be on all the time.
Old Mar 4, 2008 | 01:40 PM
Capo Cam's Avatar
ORIGINAL: 65mustang
I WILL PROBABLY HAVE TO TAKE IT INTO THE DEALERSHIP TO HAVE THE CODES PULLED, IS THAT CORRECT? THERE IS ALSO A COUPLE SMALLER FOREIGN CAR SHOPS AROUND HERE THAT MAY BE ABLE TO DO IT? CAN YOU GIVE ME AN IDEA OF WHAT A FAIR PRICE TO PULL CODES IS? THE LOCAL DEALERSHIP IS OUTRAGES ON PARTS PRICING! ARE THERE ANY HANDHELD UNITS AVAILABLE THAT YOU ARE AWARE OF THAT I COULD PLUG DIRECTLY INTO THE DIAGNOSTIC PORT OR IS THERE ANY SOFTWARE THAT I CAN LOAD ONTO MY LAPTOP THAT YOU KNOW OF? IF SO COULD YOU PLEASE PROVIDE A LINK.
THANK YOU,
CAMERON
EDIT: THE DEALER IS SAYING $80.00 TO PULL CODES. CAN AUTOZONE DO THE SAME THING? I KNOW THEY USUALLY DON'T CHARGE TO PULL CODES AROUND HERE.
Old Mar 4, 2008 | 02:23 PM
65mustang's Avatar
Autozone can do the same. Here in PA they do not charge for it, but I believe they won't clear emissions related codes. Don't quote me on that. I bought my handheld scanner on ebay for $30. It gives the codes and can clear them also. It saved me a ton of time and money. Just search for OBD II scanner.
Old Mar 4, 2008 | 02:34 PM
Capo Cam's Avatar
ORIGINAL: 65mustang
THANK YOU VERY MUCH! YEAH, I KNOW THEY WILL READ THE CODES HERE BUT WASN'T SURE ABOUT ON A VOLVO. A CO-WORKER HERE JUST LET ME KNOW THAT HIS DAD WORKS AT AUTOZONE AND WILL CLEAR THE CODES FOR ME FOR FREE IF I WANTED HIM TO.
THANKS AGAIN,
CAMERON
Old Mar 4, 2008 | 02:36 PM
Capo Cam's Avatar
ORIGINAL: 65mustang
OBD II scanner.
ANY SCANNER IN SPECIFIC OR SHOULD MOST ANY WORK? DO YOU REMEMBER THE SELLER YOU BOUGHT YOURS FROM SO THAT I CAN MAKE SURE TO GET IT FROM A RELIABLE SOURCE.
THANKS AGAIN
Old Mar 5, 2008 | 06:38 AM
65mustang's Avatar
No I don't. All I can tell you is the feedback rating was higher than 99%. I don't buy from less than that. The scanner is orange. Just make sure it says in the writeup that it can read and clear. Some don't.
Old Mar 5, 2008 | 09:26 AM
Capo Cam's Avatar
ORIGINAL: 65mustang
Will do, thanks again!
Old Mar 5, 2008 | 09:15 PM
magak2572's Avatar
I believe that the newer Volvo's use the "CAN BUS" protocol for the OBDII so make sure that you get one that can. I just got one ($100 on ebay) and it works just fine - does real time as well. Prices range from about $30 to a couple hundred depending on features.
Old Mar 7, 2008 | 12:38 PM
Capo Cam's Avatar
WENT TO AUTOZONE TODAY AND IT PULLED 3 CODES, 1 WAS ABOUT THE EVROPATIVE EMISSIONS. I AM GOING TO TRY A NEW FUEL CAP FIRST. (FUNNY THAT MY MUSTANG WAS PULLING THAT SAME CODE AND A NEW CAP CLEARED IT UP). THE OTHER TWO WERE ABOUT THE CATILITIC COVERTER AND WHAT WE ASSUME WAS PROBABLY THE O2 SENSORS. I HAD THE FELLA CLEAR THEM AND THE CHECK ENGINE LIGHT IS GONE FOR NOW . ONLY TIME WILL TELL WHEN IT POPS BACK UP. DO YOU SUGGEST THAT I TRY REPLACING OR CLEANING OUT THE "CATS"? NEW O2 SENSOR? DOES THIS EFFECT ANYTHING MAJOR? I ASSUME IT MAY RESTRICT THE EXHAUST SOME BUT I AM NOT USING THIS AS A PERFORMANCE CAR SO THAT IS NOT A HUGE CONCERN I HAVE UNLESS IT EATS UP THE GAS MILAGE OR ANYTHING?
Old Mar 7, 2008 | 10:02 PM
If they come back try getting the codes so I k now what they are.
Old Mar 8, 2008 | 02:26 AM
Capo Cam's Avatar
ORIGINAL: tech
You're right. They came back already. I will take it to "the zone" tomorrow and write them down this time. Thanks for all your help!
Old Mar 15, 2008 | 10:02 AM
Capo Cam's Avatar
TECH: Sorry for the late reply, been busy at work and such. But got a chance to run to the zone today. Pulled 2 codes, listed below:
P0422 : Definition - Catalyst efficiency low-bank 1
P0432 : Definition - Catalyst efficiency low-bank 2
Thanks in advance,
Cameron
Old Mar 15, 2008 | 11:25 AM
Any misfiring felt?
There should have been other codes with it.
Did they clear the codes?
Old Mar 15, 2008 | 04:30 PM
Capo Cam's Avatar
No misfiring felt that I know of? No, I didn't have them clear the codes this time.
Old Mar 15, 2008 | 04:59 PM
I would see if they could clear them.
Then see how long till they come back.
tngreg
Sep 5, 2022 07:27 PM
ErnstlS90
Oct 23, 2008 08:37 AM
mstrplmber
Aug 28, 2008 03:34 PM
BRB
Feb 9, 2008 12:29 AM
llama_of_doom
Aug 23, 2007 09:52 PM
