check engine light help
Old Nov 6, 2008 | 06:19 PM
ryan319's Avatar
Default check engine light help
hi, new to the forum. i just picked up a 2001 S60 T5. the check engine light is on and i had the code read. they told me it was "Boost pressure signal too low and signal too low." fromwhat i can find that is the MAP sensor.anybody have any insight or experience with this that can confirm that it's theMAP sensor?
also, the emission system service required light is on too.
thanks!
Old Nov 7, 2008 | 07:16 AM
Default RE: check engine light help
Could be the Map sensor I have seen them go bad.
To find out more I would have to know the code that they pulled.
Old Nov 27, 2008 | 09:08 AM
ryan319's Avatar
FYI, it was the MAP sensor.
Old Nov 27, 2008 | 07:56 PM
ryan319's Avatar
well the flipping light came on again today after being out for 2 weeks. stay tuned for further updates.
Old Nov 28, 2008 | 12:10 PM
ryan319's Avatar
new code was for the coolant. i reset the light and replaced the coolant with new stuff and all seems to be good.
the original problem was the map sensor.
Old Nov 28, 2008 | 01:41 PM
The coolant temp sensor or thermostat might be bad see if the light comes back on for the same code.
tngreg
Sep 5, 2022 07:27 PM
ErnstlS90
Oct 23, 2008 08:37 AM
mstrplmber
Aug 28, 2008 03:34 PM
BRB
Feb 9, 2008 12:29 AM
llama_of_doom
Aug 23, 2007 09:52 PM
