Check Engine Light, no codes
Old Jan 27, 2021 | 06:22 PM
cg23cpo's Avatar
Default Check Engine Light, no codes
2008 S60 AWD turbo, 147,000 miles purchased used. I have a check engine light on and ODB code reader (Autel AL619) is not showing any codes. Checked the gas cap and it seems to be OK. Also stopped at Autozone with CEL on and their reader showed no codes.
Any ideas?
Old Jan 27, 2021 | 07:15 PM
ES6T's Avatar
If you're sure its the CEL, you need a better scanner
100% of the time at my shop if the CEL was on there was a code we could find using VIDA - so not sure what to tell you, other that the free autozone or your autel is not finding it.
Old Jan 27, 2021 | 07:18 PM
cg23cpo's Avatar
Yes, it is the CEL. I'm thinking Volvo has them trapped outside of the generic ODBII. Any recommendations on scanner? Might be a trip to the local Volvo enthusiast garage or dealer.
Old Jan 27, 2021 | 08:06 PM
Vida is a free download easily found (Swedespeed has a copy in the ODB section) - A dice unit is ~$100
VoVosouth
Oct 23, 2020 08:00 PM
pancho
Mar 11, 2015 03:29 AM
peterz
Dec 8, 2013 07:07 PM
Capo Cam
Mar 15, 2008 04:59 PM
Musicjunkie2k
Oct 22, 2005 07:27 PM
