Chirping in the fan
Old Sep 25, 2007 | 02:59 PM
psu97's Avatar
Default Chirping in the fan
Hi everyone,
The ac/heater fan on my 2002 S60 T AWD is making a faint chirping noise when in runs. Any ideas? I can't tell at the higher speeds because the blower make too much noise. Could it be the blower motor resistor? Thanks in advance.
Brian
Old Sep 25, 2007 | 07:34 PM
Default RE: Chirping in the fan
That is usually the motor going bad.
Old Sep 26, 2007 | 09:17 AM
psu97's Avatar
Can I replace that myself? If so, where can I look for parts?
Old Sep 26, 2007 | 11:15 AM
99VolvoV70's Avatar
I replaced mine fairly easily. It was right behind the glovebox. That was on a 99 V70 though, so I don't know how different yours is. Here's one place to buy the motor: http://www.eeuroparts.com/productdet...&code=8993- $188.90. Or FCP Groton, $189.00, http://www.fcpgroton.com/p2series/p2cooling.htm (Aftermarket at FCP Groton is $109)
Old Sep 28, 2007 | 05:38 PM
Yes you can its a little more complicated then the earlier cars.
It just takes a little time.
Old Oct 8, 2007 | 02:34 PM
hohoho43's Avatar
Man.......It's a pain! I had the same problem and took it to auto shop to replace the motor blower, end up cost for $450!!!
Old Oct 18, 2007 | 01:35 AM
Volvocars's Avatar
Cut away the insulation and if you cant get the back screw off. Break it off.
Old Mar 13, 2009 | 03:40 PM
mrutherford2005's Avatar
My car is doing this right now as well, need to bring to dealer for my free blower motor.
Mine only does it when it is cold in the morning, or sometimes when I go around a corner fast(I live in MN).
Old Mar 14, 2009 | 09:06 PM
heyitsomid's Avatar
free blower motor?! mine is doing this too, I'm guessing it's going to get really annoying soon.
Old Mar 15, 2009 | 10:22 AM
My car is still under warranty....this will be one of many things I get for free. Like the engine I got.
servatius
Dec 18, 2010 10:15 PM
EDisEPIC
Mar 9, 2010 12:36 PM
golfT69
Feb 5, 2010 05:01 PM
JimBee
May 9, 2009 01:51 AM
summit
Nov 26, 2008 10:50 PM
