chirping belt & cooling tube
Old May 2, 2009 | 10:11 AM
JimBee's Avatar
Default chirping belt & cooling tube
On my '93 850, I recently noticed at idle the serpentine belt seems to be chirping in sync with a slight runout or wobble on the power steering pulley. Is there a belt dressing to use on it? If so, how would I get some on safely?
Also, the steel tube that runs across the firewall side of the engine under the exhaust manifold seems a bit corroded near the ends; do those fail? If so, please suggest how to remove it.
I also noticed a power assist line to the steering rack looks rusty. I wiped a little oil on it. Does the steering box need to come out to replace that?
As always, thanks for any help!
JB
Old May 9, 2009 | 01:51 AM
nonsense619's Avatar
i also have this problem with the chirping and wobble..sprayed a generous amount of dressing on it but did not help.stopped on its own after i did the pcv..coincidence?
servatius
Dec 18, 2010 10:15 PM
EDisEPIC
Mar 9, 2010 12:36 PM
golfT69
Feb 5, 2010 05:01 PM
psu97
Mar 15, 2009 10:22 AM
summit
Nov 26, 2008 10:50 PM
