codes
P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0068 MAP/MAF Throttle Position Correlation
P0171 Fuel Trim too Lean (Bank 1)
sounds like you need to clean your maf sensor located in your air box
to test, just unplug it. if the car runs better you found your issue
if you replace, replace only with OE or Bosch
clean you throttle body aswell
I have an ultragage diagnostic tool. I have tons of stuff stuff I can check, but I don't understand most of the readings. I have no idea what number range I am supposed to be in with all the stuff on it. It checks just about everything. I mainly use it for codes, MPG, Temp..simple stuff
timer00
03-02-2009 10:21 PM
gabyman97596
05-14-2007 09:52 PM
