Coolant fluid keeps going low at least twice a month.
Old Aug 31, 2011 | 01:33 PM
VolvoS40S60's Avatar
Question Coolant fluid keeps going low at least twice a month.
My 2001 S60 had it's coolant changed about 6 months ago. I don't see any leaks anywhere, but about twice a month I get the error message "Stop Engine Check Coolant". When I check the reservoir, it is slightly below the "Low" mark. I add the correct amount of fluid & the problem goes away for a few weeks. Can it be that there are air pokets in the radiator after all this time or is it leaking into the engine somehow? Is there a way to see if it is going into the engine or what else could be the problem? All advise is appreciated.
Old Aug 31, 2011 | 02:42 PM
elav's Avatar
I had a similar issue with my C70 (except I would see a cup or two of coolant in the passenger side front corner of the car). I replaced the hoses, thermostat, water pump, coolant cap and eventually the radiator. After all that I discovered that my over-flow bottle had a hairline crack in the bottom of it that would weep coolant under the right conditions. When it leaked it ran down a ridge in the car making it look like it was leaking from the radiator area. Take a look at that (cheap part to replace).
Old Aug 31, 2011 | 04:27 PM
MYS6T's Avatar
Remove the front splash guard. This is in the very front of the cars. Im going to bet that you will see some old Anti freeze there. The radiator is going to fail at some point it just how long it will last before the seams let go.It drips and over time 15-30 days i loose about a cup of fluid. The other thing is it may be mixing with the trany fluid. This is been know to happen but if the car is shifting ok then i would start by looking in the splash gaurd passenger side first. GL and here is a link on replacing the Rad if you so choose to. Its a $800-$1000 job at dealer
Old Sep 2, 2011 | 07:43 PM
sktrmoss's Avatar
I am gonna check on that. Mine is doing the same thing. Thx for the heads Up Mys6t
Old Sep 6, 2011 | 01:13 PM
@ MYS6T , You mentioned a link in your last post about replacing the Rad... Do you still have it?
Thanks
Old Sep 6, 2011 | 05:02 PM
MYS6T's Avatar
Fixing a Leaking Radiator
IanMitch
Oct 15, 2014 12:43 PM
Daniel Sendelbach
Jan 11, 2014 07:29 PM
ceepyou
Mar 4, 2009 08:48 PM
Scotland77
Mar 3, 2009 03:17 AM
radthes
Jan 30, 2006 04:07 AM
