Cruise control not working - P2131
Old Sep 16, 2025 | 02:34 PM
Verracciii's Avatar
Unhappy Cruise control not working - P2131
Hey there,
I own a Volvo S60 2001 2.0 T S B5204T5 M56 and I have developed an issue.
A while back my cruise control started working inconsistently, on and off. I then also got an Engine System Service required message which was a P2131 code. I cleared the code, the cruise control worked for a day but then stopped permanently. The code and message never returned. I decided to test my pedal sensors.
Here's what I tried before that:
  • Engaging while lifting the pedals
  • Engaging with the steering wheel turned at different angles
To no avail.
I have gathered some data from the sensor below and was hoping someone could help me make sense of it or even point me in the direction of a wiring diagram. I am quite new to car electrics.
Accelerator Pedal Connector (6 wires: Blue-green, Blue-white, Grey-red, Brown, Black, Black-white)
Live checks (ignition ON, chassis ground):
  • Black-white: 5V
  • Black: 0V
  • Blue-green: 11.1V (battery ~11.9V at time)
  • Blue-white: 0.817V rest → 8.65V pressed
  • Grey-red: 35 mV rest → ~50 mV pressed (jumps ±20 mV)
  • Brown: 0.428V rest → 4.3V pressed
Wiggling the harness:
  • Brown, grey-red, blue-white → stable
Resistance checks (pedal prongs, battery disconnected):
  • Blue-white ↔ Grey-red: 0 Ω
  • Blue-white ↔ Blue-green: ~10 MΩ
  • Grey-red ↔ Blue-green: 0 Ω
  • Brown ↔ Blue-green: 0 Ω
Resistance checks (harness side, battery disconnected):
  • Blue-white ↔ Grey-red: 5.3 kΩ
  • Blue-white ↔ Blue-green: 5.2 kΩ
  • Grey-red ↔ Blue-green: 11 Ω
  • Black ↔ Blue-green: 12 Ω
  • Brown ↔ Blue-green: 2.6 kΩ
Brake Pedal Switch (live test)
  • Yellow: 11.5V pressed, ~11 mV released
  • Red: 0V
Clutch Pedal Switch (live test)
  • Black wire: 3.3V rest → 1V pressed
  • Brown wire: 1.2–33 mV
Observations
  • Grey-red shows almost no voltage response (stuck near 0 V).
  • Blue-white shows abnormally high max voltage (8.6 V).
  • Pedal prong tests show shorts: signals tied to each other and to 12V.
  • Harness side also shows low resistance between signal and 12V supply, and ground and supply.
  • Battery low at ~11.9V.
I appreciate any help at all!!!
hgshaw
Oct 13, 2021 02:53 AM
derrickb
Jun 9, 2013 10:20 AM
rspi
Jul 31, 2012 07:38 AM
Bruce Wayne
Apr 3, 2009 11:10 PM
m1964
Mar 13, 2006 07:53 PM
