Dashboard screen problems after 60k service
Old Oct 8, 2018 | 06:40 PM
shawn_krueger's Avatar
Default Dashboard screen problems after 60k service
Hello. I have a 2015 V60 that is just about to hit 60k miles. I have a 1700mi road trip coming up and so I scheduled my 60k service with my local "European specialty" mechanics. All went well but when I got the car back the dash screen stuff is all out of sorts. I can get into the "My Car" section, but all the audio, clock etc... functions will not work. If I get it to turn on, the menu pops up, but if you scroll through to individual sections, nothing works.
The mechanic had the car back for a few hours today and they seemed to rule out anything they might have done during the 60k mile service as the root of the problem. Of course. Sometimes a coincidence is just that, but I'm loathe to spend money on exploring a problem that didn't exist when I brought the dumb thing into them in the first place.
Does anyone else have this problem or have an idea what might be done to correct it? I'm quickly starting to despise this vehicle. I like the fuel economy and the smoothness of the ride, but I get frequent check engine codes for "lean fuel system" when the weather changes or I run the tank too low on a highway trip.
Old Oct 8, 2018 | 07:27 PM
ES6T's Avatar
A 60k service (or any service, for that matter) has nothing to do with problems from the center screen.
And the weather isn't causing your check engine light. There is a problem that needs to be diagnosed .
Old Oct 8, 2018 | 09:32 PM
Well, I guess it's a coincidence then. It just seems quite odd that it would happen immediately after I turned the vehicle on after having had the car in for service.
Old Oct 8, 2018 | 10:32 PM
ES6T's Avatar
A 60k is only an oil change and cabin filter replacement.
Old Oct 8, 2018 | 11:44 PM
I was told (and paid for) a lot more than that on the 60K service. I've read that what you suggest is all that is necessary...but I've also read where a lot more is necessary. Shame on me for believing my mechanic...but I certainly am not someone with the time or knowledge to do these things myself. Again, shame on me.
I guess my question is still out there... As it isn't the 60K service, what would cause many of the dashboard screen functions (radio, clock, Bluetooth, CD etc...) to suddenly stop working when they worked fully when I dropped the car off that morning? The only thing that will display on the screen and still work is the "My Car" function which allows the "Sport" mode. This will make for optimum handling when I drive this expensive piece of garbage into the nearest lake. Kidding. Kind of.
Is is it fuses? Software issue? Something disconnected and not reconnected properly? Is it in the possession of demons? What would make a previously functioning system stop working like this? Has no one encountered this?
Old Oct 9, 2018 | 06:22 AM
ES6T's Avatar
All services are outlined in the maintenance manual for the car. Goes to show you that just because a repair shop isn't a dealership doesn't mean they are honest.
I haven't encountered that problem yet. You'll probably need to take it to the dealer to see what codes are stored.
brandtrn
May 29, 2017 11:50 AM
akabond
Mar 4, 2011 10:05 PM
creamsoda
Oct 18, 2008 05:28 PM
OBXwahoo
Apr 20, 2007 03:45 AM
gandi
Mar 26, 2007 02:50 PM
