Door locks cycle when I am washing the car
Well we may have an issue but I am not sure.
Today was the first time I washed the car since getting the service completed for the TSB lock service. There is something odd happening.
When spraying the car doors with the wand, the door locks kept cycling on / off. You can hear the chirp and see the lights on the side mirrors flash. Sometimes just spraying against the window would do it. It does it on all doors.
Since buying the car I've washed the car many times but never saw it do what it did today. I'm worried that there is water ingress into the door lock mechanisms. The car doors I'm familiar with always had plastic sheeting that protected the electronics from water. When the door panels were removed to fix the locks, could that barrier have been breached?
Plus today I also noticed the top of the drivers door panel wasn't fully engaged with the clip. I gave a nice bang and it attached, now it isn't wobbly.
I had the service done on 4/29/2020.
Is this normal and I just never noticed it before or did something happen during the lock replacement? I don't have a good history with this service department, I caught them doing a very bad thing on a TSB for my V50.
there is a plastic sheet under the door card that reattaches via a thick gummy compound - but that that should keep moisture off the card not keep water out of the door's interior. I'd check to make sure the seal around the base of the window is properly in place. I'd bet that the window relies on the top of the door card to press it against the seal and that's where its leaking.
What is a door card? Never mind, now that it isn't the middle of the night I looked it up -- "A door card or a door panel is an insert on the door of a vehicle that covers the door's internal components."
Plus if it is loose it happened during the recent servicing and i don't think I should be pulling the door panels.
door card is the term for the interior door panel. most wrap over the top and have a moulding that fits the inside of the window Any water that finds its way down between the glass and exterior moulding should drain down and out of the weep holes. In re-reading your post, you noted it happens when you spray on any of the windows? that makes me wondering if you were actually triggering an alarm function or a window position sensor. Does your car normally drop the windows a fraction when opening the door? (My VW CC lowers its windows about 1/4 inch when opening the doors to give it clearance from the rubber seals) Just wondering if the pressure on the window is triggering that feature. Given this happened as a result of service at a shop, I'd bring it back and have them inspect their work. you'd need to open up the door to see if interior parts are getting wet or if its just the mechanical action of the water pressure pushing the glass. What happens if you push on the glass with your hands (ie emulating the water pressure?)
Windows don't drop.
I see another post says their car does it.
^^ This ^^
Take the key out of your pocket when washing. Water from the hose is triggering the capacitive lock/unlock sensors on the door handles the same way your hand would. Leave the key out of range and it won't happen.
![Smile](https://volvoforums.com/forum/images/smilies/smile.gif)
Hm? A positive thought, maybe the rapid cycling is a good way to keep all lock mechanisms from gumming up. I guess it is better than one of the Jaguars I owned that had a mind of its own. The doors would mysteriously unlock on their own, not a good thing when you come out of the restaurant and find them unlocked.
