Drivers Door module
Old Dec 9, 2009 | 09:07 PM
cordoba's Avatar
Default Drivers Door module
Something is up with the drivers door module. When I shut off the motor and exit the vehicle, about 30 seconds later a ticking noise starts to come from the drivers door...around the height of where the door module is. If I stay inside the car and press and hold any PW or PL buttons down, the noise stops. A couple of times the controls have stopped working all together -no window control, no power lock control and the lights in the buttons are off. If I pull the fuse for the module and put it back, all power to the module is restored.
Anyone experience this? I'm starting to think I need to replace the entire module unless someone can tell me if it's serviceable. Any idea how much this part is going to cost at Volvo?
Old Dec 11, 2009 | 01:35 PM
Blownby's Avatar
What year S60 is it.And I believe there is a vin split for that particular part.I would need the last 6 of your VIN to make sure i get the right price on it.
Old Dec 14, 2009 | 09:46 PM
cordoba's Avatar
Sorry for the late response.
It's an 01. Last 6 digits are 028699
Thanks for looking into it for me.
Old Dec 15, 2009 | 10:08 AM
Blownby's Avatar
No biggie.
Part # 30658116
be about 435.oo
There is also a software its showing.Its called a DDM reload software.It is 78 bucks for the software also.
Old Dec 18, 2009 | 08:29 PM
cordoba's Avatar
Thanks Blownby. I'll check it out.
Appreciate it!
Old Dec 21, 2009 | 06:01 PM
cordoba's Avatar
The weirdest thing is happening now. The window switch for the drivers window will not work but when I press the 'L' button, (normally to adjust the LS power mirror), the drivers window and drivers side rear window both go down at the same time. When I press the 'R' button they go up.
Haven't had time to get it check out yet. I better get to it soon before the break pedal starts to act as throttle and the gas pedal starts to break. lol.
drag
Jul 27, 2013 10:37 AM
cordoba
May 15, 2011 06:15 PM
cordoba
Feb 9, 2010 12:50 PM
volvoz
Sep 12, 2005 08:38 PM
macca66
Apr 2, 2005 11:09 PM
