ECU chip question
RE: ECU chip question
I have a 1999 s70 awd with a SpeedTuning USA ecu upgrade. I love mine. Great kick in the pants feel.
Everyones gain is going to be different so can't say what you will or wont gain. Assume about 20-30 Hp and the same with Ft-Lb's of Torque.
Also ST USA is good if you don't really plan on more exstensive engine mods. However I would suggest looking into the BSR PPC and the RICA and IPD softloaders that are available. Yeah they are way more exspensive then ST USA, but believe me they are a whole hell of a lot better as well. Your car will run rich on the ST USA ecu upgrade. No way around it.
ORIGINAL: S60 Jeffy
alrite thanks. really the other thing im thinking of doing is exhaust and an air intake, but thats down the road. so do u think i should go with something different from ST USA if im doing that?
After these are done go with the BSR PPC and or the IPD and or RICA softloader systems. Exspensive but worth the money.
ORIGINAL: S60 Jeffy
ok. thanks so much for the help. but for the intake i was thinking going with eurosport. have u heard good things or bad things bout it?
Looking at the one for you seen here.
The heatshield doesn't look as good as the one that came with mine. But I am sure it does ok. It wont shield the filter from all the heat in the engine bay like the OEM airbox does. Neither does my EST heatshield.
It is truly more of a under the hood apperance peice and sound maker. You will hear it sucking in air. Sounds great.
