Engine dying when coming to a stop
Old Oct 24, 2006 | 06:15 PM
bbearden's Avatar
Default Engine dying when coming to a stop
My fiance has a 2001 S60 2.5 and her check engine light is on. Haven't been able to take it down to have the code read but I'll mention some symptoms and I would greatl appreciate it if anyone here knows what the problem might be. When she comes to a stop, the engine will die. It restarts very easily and doesn't always die at stops, but it is becoming more frequent. The oil and air filters are fresh and I cleaned the MAF sensor. Any ideas? EGR? O2 sensors? Thanks in advance!
Old Oct 24, 2006 | 10:09 PM
Volvo2001's Avatar
Default RE: Engine dying when coming to a stop
Could be Injectors, or Fuel Pump, Gas Cap loose. . . . Could be a number of things. You will get a much better idea when you get the code read.
Take it to your local Autozone or Advance Auto. . . They'll read it for free and clear them for you too.
Old Oct 24, 2006 | 11:52 PM
Ihatespeedbumps's Avatar
ORIGINAL: Volvo2001
A lose gas cap won't cause the engine to die. I'm almost 99% sure it's related to the ETM. Sometimes ETM problems are even covered under warranty, so if you take it to the dealer it MAY not cost you anything.
Old Oct 25, 2006 | 12:17 AM
bbearden's Avatar
Thanks for the advice guys. Sounds like an ETM issue after doing a bit of research on the net. Did the lawsuit ever get pushed through to allow owners to get a free cleaning at the dealership? Any ideas what code will be thrown if I get a diganostic done if this is an ETM failure? Thanks again for the advice!
Old Oct 25, 2006 | 05:53 PM
Volvo2001's Avatar
Reading the codes will most likely tell you if it's the ETM.
In either case, the ETM is covered for 10 years or 200,000 miles.
Your choice of having the dealer charge you for a diagnostic and hope that the ETM is the problem and he won't charge you or just stop buy Autozone or Advance Auto and read the codes for free first.
dman777
Aug 3, 2020 07:06 PM
Brandy1
2001-2013 model year V70
Nov 24, 2012 06:38 PM
Letterkenny
Mar 14, 2010 04:53 PM
msennett
Suspension
20
Sep 13, 2008 11:30 AM
oldmans90
Sep 17, 2006 01:08 PM
