Engine knocking noise
Old Feb 6, 2010 | 10:25 PM
mazzaroth's Avatar
Default Engine knocking noise
We are looking at a 2002 2.4l T5. It drives nice but has a grinding sound turning sharp and under the hood there is a knocking sound. Is this normal for that age or a sign of a problem?
Old Feb 7, 2010 | 09:48 PM
FredMc's Avatar
Neither is normal. Could be wheel bearing on left side. Could be rod knock which is not good.
Old Feb 10, 2010 | 01:23 PM
endothrow's Avatar
I am not sure about the engine knock but I am pretty sure the grinding that you are hearing when you turn sharply is the wheel tread rubbing against the wheel well splash guard. I have a 2002 T5 with the OEM Pirelli's sized exactly to the original sizes and I still have an issue with rubbing. The good news is that it is on an aluminum plate that is removable if it is driving you crazy. This isn't uncommon as I have heard this from other S60 owners.
Old Feb 10, 2010 | 07:42 PM
malaka's Avatar
Rod knock is the death knell of the deal. You need it to be evaluated by a
professional who can i.d. this serious problem or rule it out.
Old Feb 10, 2010 | 11:11 PM
JTapper's Avatar
Bad idea.
You end up rubbing through the plastic behind it, it ends up catching on the tire and you yank the whole damn thing out. Leave those plates there!
**Learn from someone else who thought that was a good idea at one time, and is short a splash guard because of it.**
Old Feb 12, 2010 | 05:23 PM
buci's Avatar
What kind of fuel are you using,regular?
LOVEvolvos
Apr 24, 2012 10:36 PM
macdogd
Mar 17, 2009 08:46 PM
Wing
Jan 30, 2008 01:52 AM
chris71 GB
Oct 27, 2005 08:54 PM
ripleydog
Jan 31, 2005 01:26 AM
