Engine light won't go off?
Old Nov 21, 2010 | 10:40 PM
Aethera's Avatar
Default Engine light won't go off?
I've gone to autozone several times and it keeps giving the same emissions code. They say it's just the gas cap. I bought a new one and the light hasn't gone off, been well over a week so I gave it time. My BF told me to try a higher grade gas, I did, no change. both tries I had the light shut off and it came back on.
Any idea why the light won't go off? I don't want to ignore it because if something else goes wrong I won't be alerted because I'll just think it's the emissions thing.
Old Nov 21, 2010 | 10:47 PM
02s602.4t's Avatar
If the reason truly is cheap gas, take the negative end of the battery off for 30 minutes which will reset the ECM. The check engine light will reset during this process as well, but will come back on if there is a real problem with the emissions. If it does come back on, you more than likely have an O2 sensor going bad or a fuel-air mixture problem.
Old Nov 23, 2010 | 08:45 AM
Aethera's Avatar
I did what you said before. How do you check to see if it's either of those problems?
Old Nov 23, 2010 | 10:48 AM
Manu Noypi's Avatar
What was the DTC when u have ur car read @ Autozone
Old Nov 23, 2010 | 12:17 PM
Aethera's Avatar
Manu, I can not remember. But I remember it was a emissions code and they said it was no big deal, that I needed a gas cap. I remember the paper saying emissions were leaking and all that.
Old Dec 10, 2010 | 04:42 PM
mbsjshad's Avatar
Smile Could it be?
I have been getting these check engine lights off and on for months now. I think I finally got it. I think the gas cap vent hole that was in the cap was clogged. I cleaned the cap inside and out and the light has been off for a month now. The longest ever.
Old Dec 10, 2010 | 11:37 PM
Mad Matt's Avatar
Take it back to Autozone and post the actual code that they pull. It's kinda hard to say what it can be with out it.
Old Dec 12, 2010 | 09:10 AM
capsfan69's Avatar
Willing to bet that it's "Small Evap Leak". They told me that it was the gas cap a couple of times but it turned out to be the "J" hose which had a crack and is a known issue with these cars. Here is the part you are looking for.
It's part "A"....http://www.ipdusa.com/Volvo-S60-P2/E...p-74-395-5034/
Old Dec 17, 2010 | 06:23 PM
ES6T's Avatar
Information removed.
Old Jan 3, 2011 | 04:08 PM
maxxiegt's Avatar
Where can I obtain a diagnostic report on my 91volvo 940se? O r is there something else that can be done to obtain a diagnostic report? Help... cel won't go off
volvoralph
Jul 19, 2016 04:19 PM
Moxiegurl
May 9, 2016 07:35 PM
analogies
Apr 3, 2012 03:42 AM
mcaanda
Apr 27, 2010 01:00 PM
Pyrate
Jun 15, 2009 02:17 PM
