Engine Surging While Idling
Old Jul 21, 2022 | 03:05 PM
lightstamp's Avatar
Default Engine Surging While Idling
I was at a stop waiting for traffic to slowly pass in front before I could turn into the road. All of the motor did an increasing rev as if I had floored the accelerator pedal. All I could do was push on the brake as hard as possible and Put car into Park and cut off the engine., This is time when i started the engine, it continued with the high RPM motor rev. Turned it back off and was considering calling a wrecker. Since I was quite a distance from home. I tried it one more time and it started normally and had no more issues, The dealership had an examination of the issue last year after it had done this several times. They basically said the only way they could find the cause would be for it to happen while they had it in the shop. Has anyone else experienced this? (S60 T5 Premiere.
Old Jul 21, 2022 | 04:34 PM
what year is your car? Starting in 2000 or so, Volvos went to an electronic throttle mechanism (aka drive by wire). There's a position sensor in the accelerator pedal and then there's the ETM (the throttle body). Since the problem went away when you stopped and restarted, I'd also look for other things like a relay involved.
Old Jul 21, 2022 | 04:46 PM
lightstamp's Avatar
2016 S60 T5 Premiere
Old Jul 22, 2022 | 11:20 AM
For something that new, I'd bring it to the dealer for a full VIDA scan and see if there's any available or required software updates. My guess its either software, wiring/relay, the pedal sensor or the throttle body. The pedal sensor runs $150-200, throttle body $500-600...
Tim Garvie-Maclean
Mar 7, 2014 12:04 PM
RSslc
2001-2013 model year V70
Nov 28, 2013 09:11 AM
neonurse
May 27, 2012 07:54 PM
bearbutt
Jun 11, 2011 04:49 PM
RichM
Feb 17, 2008 09:52 AM
