Engine system urgent and transmission service required!!
Old Aug 22, 2018 | 08:43 PM
Helio's Avatar
Default Engine system urgent and transmission service required!!
Hi my 2001 volvo s60 2.4L T wont go past 20 mph or above 2000 rpm i recently did oil change and transmission oil job any clue as wat it may be.
Old Aug 23, 2018 | 08:45 AM
You need to have your car scanned for the check engine fault codes - no point in guessing without it. Considering you did a transmission job, you should double check your fluid levels using the proper warm up procedure. You can find a friendly indy tech to scan, rent an OBD2 scanner from Autozone or similar or buy one at Harbor Freight or onlin.
Old Aug 23, 2018 | 04:59 PM
tony1963's Avatar
Sounds like a throttle body or ETM issue to me.
Brandonis123
Sep 18, 2015 03:02 PM
logisoft
Jan 29, 2010 08:56 AM
exxxer
Feb 1, 2008 04:35 PM
krakajacka
Dec 1, 2007 12:37 PM
dean02S60
Jan 21, 2007 12:46 AM
