Front end noise when turning left
Old Mar 8, 2023 | 09:46 AM
Alo782's Avatar
Default Front end noise when turning left
Hey everyone
I have a 2014 s60 t5. When I turn the wheel left it makes a sound similar to a honk of a horn the noise is constant till i turn the wheel back to the center . The noise only occurs when I'm going above about 15mph.and as stated only when I am turning left.
to give a little bit more detail
This only happens as well when the wheel is turn about 1/4 to the left once past that point it doesn't make the noise. If I am at a stand still and turn it nothing. I have checked the wheel well to see if something was rubbing and there is nothing that could be. I have also checked the power steering fluid and it is full.
anyone else run into something like this?
Old Mar 8, 2023 | 02:07 PM
are you saying the horn honks or just an odd noise? I'd do a quick test by pulling the fuse for the horn just to see if the noise stops. If its the horn then I'd suspect there's a connection issue in the steering wheel hub. Otherwise, I'd be checking axle boots for leaks and listen for clunks etc. Another possible cause is a wheel bearing - when you turn left at speed, the car puts more weight on the right side of the car and that can make the wheel bearing "moan".
\/sauce
Apr 21, 2017 06:20 AM
Brooklynite
Feb 16, 2013 07:24 PM
mgacarnut
May 8, 2009 11:19 PM
djgiovanni
May 13, 2008 09:29 PM
vicki
May 9, 2005 12:49 AM
