Fubar after TB cleaning
It is possible something got knocked loose when removing hose that connects underneath to the throttle body.
I will unplug the MAF and re-sit it. Is the PTC Element the thick hose in bottom/front/by oil dip stick that connects the turbo hose (hose over top of engine?)?
Really appreciate the response.
Thanks Mad Matt. Checked the PTC and MAF. Disconnected MAF sensor. Nothing seems loose. The car still will not idle, won't stay on without my foot on the gas. Would the throttle body gasket being put on incorrectly cause a leak? It has a slight ridge and I wasn't sure which side goes up.
The CEL is not on. Would damaged electroincs on the throttle body cause this problem? Is it possible to replace just the electronics?
Here's some info that might help.
https://volvoforums.com/forum/volvo-v70-13/throttle-body-replaced-no-software-44999/
https://volvoforums.com/forum/members/bobec-25604-albums-v70-etm-632/
http://www.matthewsvolvosite.com/for...p?f=12&t=29885
http://www.matthewsvolvosite.com/for...p?f=12&t=30500
PM me if you have specific questions. Check and double check the supply voltage, lubricate the o-rings with thin synthetic oil, cleaning could make them very dry and add friction to the rotation of the plate.
