Fuel leaking (dripping) 04 s60r
Old Jan 30, 2017 | 07:53 AM
willsern's Avatar
Default Fuel leaking (dripping) 04 s60r
Hey guys I filled my car up last week and noticed overnight a wet spot under the drivers side rear area. It's dripping from the tank, but I can't pin point the location. The left side of the tank was wet and it looks like it's coming from the top somewhere. Fuel pump is on the other side so not sure if that's the problem because I've heard of them leaking. I'm parked downhill a little. Also I burned 1/8 of a tank or one notch (not sure if it's actually 1/8 of a tank because I think there's still more gas when the fuel gauge gets down to red likes reserve) driving 12 miles in the city. Now it's all stop signs and I only drove 2 miles each cycle. It's likely I'm averaging 6 mpg or something ridiculous because it's all 1-3 gears and all accelerating. Also the thermostat doesn't even open up by the time I get to school, so it could be running really rich still. I'm wondering if the leak is that bad or just city driving because this is city driving at its finest.
Im at half a tank now and I've driven 113 miles since fill up. I was driving highways and back roads the past weekend. If someone could tell me how many gallons each notch represents I could get a rough estimate of the mpg , that would be great. Then I would need to fix the leak for safety and so my driveway doesn't have gas all over it.
Thanks a lot I really appreciate it
Old Feb 4, 2017 | 10:06 AM
doesn't your car's info center show average MPGs? you should be able to reset to zero out and see what's what. Regarding the leaking, sounds like it could be in the area of the filler neck. is that the side that's wet? On the thermostat question - that's really a mechanical switch - more likely you may have a problem with the engine coolant temp sensor, which is located directly below the thermostat cover. Simple to replace for about $50 and throw in a new OEM thermostat for $15 and see if that helps.
Old Feb 4, 2017 | 12:43 PM
ES6T's Avatar
Fuel pumps are common to leak, but it is on the passenger side. Best bet is to remove the back seat and remove the access covers to check.
Old Feb 4, 2017 | 08:05 PM
willsern's Avatar
I just mentioned the thermostat to tell you it's not even up to temperature so maybe it was running rich, but disregard that. The fuel leak is on the left side. The right side is the fuel door. I averaged 17 mpg based off of my miliage and gallons used when I filled up again. The leak is definetly a problem. It only leaks at 3/4 tank and up.
Aren't there two fuel pumps? One on each side?
Old Feb 5, 2017 | 10:00 AM
ES6T's Avatar
Just one pump. But there is a level sender on the drivers side. It could be leaking from that seal.
Old Feb 5, 2017 | 06:48 PM
willsern's Avatar
Level sender? Is that located on the top of the tank because it appears that's where the leak is coming from. Also can I access it from under the rear seats if do I have to drop the tank?
Thank you
Old Feb 6, 2017 | 06:29 AM
ES6T's Avatar
If you have a plastic tank, you access both the pump and level sender from under the seat.
Old Feb 6, 2017 | 04:56 PM
willsern's Avatar
Ok thanks a lot. Ill check tomorrow and let you know if that's it.
Old Feb 6, 2017 | 05:52 PM
Smith Volvo's Avatar
Banned
we sell a few of the left hand sending units - the plastic top where the o ring sits can crack
Old Feb 7, 2017 | 11:16 AM
willsern's Avatar
Well if you're right, I'll be buying one from you
Old Feb 7, 2017 | 09:44 PM
willsern's Avatar
Here it is. As soon as I took that aluminum off I could smell lots of fumes! Got it now I just need to replace it. Now is it the black thing surrounding the sender? I want to order the part and take the sender apart once if possible. Im assuming that's right because fcp sells the sender and then just that which they call "sender oring"
Old Feb 7, 2017 | 09:48 PM
Banned
here is my exploded view:
tank sender DSL. 6CYL. 5CYL EXC (CA), (US). 5CYL (CA), (US).. Fits: 2004 Volvo S60 2.4l 5 cylinder | Volvo Wholesale Parts Direct
Old Feb 7, 2017 | 10:25 PM
ES6T's Avatar
At the very minimum, you will need the o-ring. The sender could also be cracked. Hard to tell without inspecting it.
Old Feb 8, 2017 | 07:31 AM
willsern's Avatar
Alright thanks a lot. I really appreciate it. I'll order the o ring and the "screw" which it's called on the skematic and go from there. I'll let you know my results
Old Feb 8, 2017 | 09:30 PM
willsern's Avatar
So my local dealership had the parts in stock so I picked them up because I figured shouldn't be messing around with a fuel leak. Test drove and didn't see and gas that used to sit on top of the sender. Ill find out for sure if its fixed when I fill it up. Tuesday is when shell has 20 cents off 93...
Old Feb 8, 2017 | 10:24 PM
Banned
sounds like you nailed it
Old Feb 22, 2017 | 10:28 AM
  #17
willsern's Avatar
Filled up yesterday doesn't leak. Thanks for the help
MARKEMARK
Nov 22, 2014 07:20 AM
jayson44
Apr 24, 2013 08:03 PM
dsniner
Feb 19, 2008 09:26 PM
pawel
Aug 3, 2006 11:19 PM
elballoonrat
Aug 20, 2005 11:45 PM
