Fuel Pressure Pipe Replacement
Old Jun 3, 2012 | 04:25 PM
odbii's Avatar
Default Fuel Pressure Pipe Replacement
Does anyone know how to repair (resplice or replace) the fuel pressure pipe from the filter to the engine or where it goes from there. It's part number 30683028.
It was cut and needs to be replace.
Thanks
2007 Volvo S60 2.5T California Spec
Old Jun 3, 2012 | 05:47 PM
I would go with a new one. The fuel line connects to a metal line by the subframe. So it is not really all that bad to replace.
Old Jun 4, 2012 | 10:59 AM
odbii's Avatar
Do I have to drop the fuel tank to replace? Any info on what is involved to replace this?
Thanks in advance tech.
Old Jun 4, 2012 | 10:21 PM
If it is between the filter and motor like under the passenger seat then no you do not have to drop the tank.
You should be able to disconnect at the filter then remove the line cover and then disconnect at the motor. Then install the new one.
MntnDewMan
Apr 3, 2024 04:05 PM
Mustsail
2001-2013 model year V70
May 10, 2014 02:44 PM
Rozzee
Jun 22, 2013 11:53 AM
Sparkle
Oct 27, 2009 01:40 PM
Tamsen
May 19, 2009 07:31 PM
