Gas
Old Dec 13, 2006 | 03:34 PM
notny41's Avatar
Default Gas
I'm sure there's probably been many discussions on this already but I don't see any recent ones.
I know the manual says to use at least 90 octane gas in my 02 S60 AWD. I tried a tank of 89 octane and haven't noticed much of anything irregular.
Am I doing a terrible injustice to my vehicle by using the lesser octane gas?
Old Dec 13, 2006 | 11:01 PM
Fisher's Avatar
Default RE: Gas
The purists will tell you yes, but my opinion is no. There is nothing wrong with what you are doing. If you don't notice any difference then your fine. I run 87 in mine but with a supplemental additive.
Old Dec 14, 2006 | 12:46 PM
jeffrey2's Avatar
Default RE: Gas
I was just going to post a similar message. Last week I accidentally put 89 in our S60 Turbo for the first time; the mileage for that tank of gas skyrocketed from 21 mpg (92 octane) to 26 mpg (89 octane); and I've been doing the exact same driving.
Does the mileage computer just get confused with the different octane or did I stumble on a cheaper golden egg?
Old Dec 15, 2006 | 01:12 AM
Volvo2001's Avatar
Default RE: Gas
I tried putting 87 octane in my 01 S60 (three times) and my CEL Light came on with a P0422 Code on it.
Dealer (Service Tech) said to add 93 Octane and clear code and that will solve the CEL problem.
I Did what he said and it solved the problem, but I, being the hard headed person that I am, I wanted to make sure.
I waited about a month and put in 87 octane, the CEL came on with the same code, I added 93 octane and cleared code and I solved the problem.
This time I waited two months and added 87 octane again. Sure enough, CEL came on and same P0422 code.
I convinced myself that, at least with my S60, it is very picky on octane. So I guess I'll stay with 93 Octane
Old Dec 15, 2006 | 03:01 AM
gordon368's Avatar
Default RE: Gas
thats weird, I have an 01 s80 t6, I've never had probleme with 87 octane in my s80, i put it in a few times..... But 95% of the time i use 93 octane..
Old Dec 15, 2006 | 04:50 PM
studd34000's Avatar
Default RE: Gas
i belive that we should always treat are cars well, and they will treat us well. so i always use 91 in my t6 but thats here in utah. my buddy that has a 99 s80 t6 put 87 in his, and he car threw all kinds of knock codes. the dealer said that it did a number on his plugs and stuff.
Old Dec 15, 2006 | 07:11 PM
Fisher's Avatar
Default RE: Gas
ORIGINAL: studd34000
...and he car threw all kinds of knock codes. the dealer said that it did a number on his plugs and stuff...
I don't doubt that is what you heard, but I do doubt that "it did a number on his plugs and stuff". The spark plug does not know what octane you are running, the spark is not going to change as a result. The timing might, but I can't see how this would affect the spark plug.
For high pressure turbos, yes I can see how you might suffer a performance loss. For my low pressure turbo, and especially if you do not notice any difference, lower octane is not going to hurt anything. My owner's manual states that I can run the lower octane. If your manual doesn't then you shouldn't. However, if the manual says you can, but you are throwing codes with lower octane, you probably need a tuneup.
Old Dec 18, 2006 | 05:08 PM
Catchincotton's Avatar
Default RE: Gas
[align=left]how stuff works has the info on octane!
Here is some neat stuff I didn't know
http://auto.howstuffworks.com/question90.htm
Later
Cotton
[/align]
wildbill
Jul 26, 2009 07:09 AM
dman777
Jan 23, 2008 12:08 AM
jollygoodgold
Jul 16, 2007 12:06 PM
billder
Aug 8, 2004 12:01 AM
osbert
Mar 28, 2004 10:20 AM
