Gas trap does not lock
I just bought a 2002 S60 and this car had all the recalls done but I realized there is one problem that I could not detect when I bought it: therefueling trap door does not stay shut. Of course the seller was mumm. Well the risk of buying from a private seller than a dealer. No taxes, but you get what you pay for.
I wonder if this is some sort of feature or if it is simply broken.
When I put my finger inside, I can feel no latch
RE: Gas trap does not lock
The door has a locking mechanism that engages at 5mph if the door had been unlocked for refueling. Likely this lock is broken. Maybe try a quick fix if you don't care about the locking part. There are a decent amount of threads about this topic here so search up.
Thanks! I read about the automatic locking mechanism but unfortunately it does not work and this is one thing I did not inspect when I was looking at the car. I looked at the engine, the body, the controls but not the details.
It is still a great car but that will bother me until it is fixed.
I will look for other threads. I guess it is not model specific, of course, it has to exist with all the Vs of the same generation.
Thanks for your answer!
The locking mechanism engaged with the door slightly open.
I suppose the hinge mechanism avoid this issue, or maybe the trick would be to push on the door then push on the lock button.
Little thing the previous owner probably knew already but I will be kind with her.
No that is for the older cars (S70)
What you will need is teh gas door hinge. In the picture in the link see the metal spring in the hinge?
That plastic part should be what you need. See if the metal spring looks like it is hooked under plastic like in the middle of the spring.
Well, it is fixed. I just played with the spring and it allowed me to push it in all the way. Then all I did was drive and I could hear the little noise from it locking.
So all is fine.
Thanks for the help! New (to me) car, I am a little anxious about it, as always when you buy from private seller.
So all is fine.
westcovinavolvo
08-07-2011 08:59 AM
