Great maintenance info...
Old Oct 13, 2008 | 12:30 PM
cfcdh3's Avatar
Default Great maintenance info...
All,
I'm new to this site. Just bought an S60T with 96K from the original owner (someone I've known for a long time). I do all or most of my own maintenance, so I was discouraged to discover no Haynes manual was available for the car. However, after reviewing the posts on this site, I found all of the right information to do the trans fluid replacement (the 3 drain/fill method) using Mobil AFT 3309 ordered from a recommended source on this site. Also replaced the timing belt, tensioner and idler pulley ALSO by recommendation from this site. All of the tips from the moderators and others have been great. No new input to add for either job... the direction and tips for both are dead on. Thanks!!!
-CFC
Old Oct 13, 2008 | 12:40 PM
Default RE: Great maintenance info...
Glad it helped thats what we are here for.
Old Oct 13, 2008 | 04:15 PM
cjones16's Avatar
Good, I also Noticed I learn a lot more helpful hints/tips on these forums
If you would like a repair manual look for VADIS on Ebay or Torrent
Old Oct 15, 2008 | 03:06 PM
cfcdh3's Avatar
Torrent? What's that?
This next question would probably be best answered in another post and I'm sure it's already answered in an existing thread... but... What is the MOST LIKELY suspect for the clunking noise I hear in the front end when I go over a bump, lip of my driveway, etc.? 2002 S60, original struts and other front end equipment. No other symptoms. Thanks!
Old Oct 15, 2008 | 05:21 PM
cjones16's Avatar
Here for more information of a torrent http://en.wikipedia.org/wiki/.torrent
the rear clunking noise could be exhaust, end links, sway bar worn bushings.
nortons
Feb 22, 2015 11:14 PM
nicolaselias
Mar 24, 2011 08:48 PM
bluemagicbus
Feb 21, 2008 05:56 AM
FELTON_BROWN
Dec 5, 2007 06:57 PM
