having trouble changing the sway bar links.
I'm trying to change the front sway bar links on my '01 S60 and I cannot get a socket around the top bolt that's attached to the strut due to space constraints. It's 18mm. I can get an open end wrench around it but there's not enough room to crank the wrench.
What are other peoples experience?
So that's my problem. I only have an 18mm impact socket!
I'll run out tomorrow and pick up a chrome socket. Can I use an impact gun with it or do you recommend doing it by hand?
Thanks Tech!!
Thanks Tech!!
I was finally able to get them off thanks to your help Tech.
It drove me nuts for a little bit as the old ones used 19mm where the OEMs I bought were 18mm. Had to make a couple of trips to the store for new sockets. My set did not have 18 or 19mm
Once I got the new ones on and tightened up by hand I put the impact gun on and cranked them a little more. Should be good for another 6 months.
thanks again.
thanks again.
