High Engine Temperature
Old Mar 25, 2011 | 02:35 PM
esb231's Avatar
Default High Engine Temperature
I have a 2001 s60 2.4T and just recently replaced the ECT sensor and thermostat. A couple hundred miles after doing so my temperature gauge has been acting up. Mainly it has been going all the way to the hot side and I've been getting the "High Engine Temp" message that also says "Stop Car Safely ASAP". I am assuming that my thermostat may not be operating properly. I got it from ipdusa.com.
Can anyone give me suggestions on this issue and am I correct in my diagnosis?
Old Mar 27, 2011 | 12:11 PM
ed7's Avatar
ed7
If the coolant level is good and you can't feel the difference in heat radiating from under the hood, verify temp with a thermocouple on your digital volt meter or by using an infrared thermometer or find someone who does.
By verifying the temp, you'll know if it's the sensor or the t-stat.
Ed
shoeboxOH
2001-2013 model year V70
Sep 1, 2014 07:41 PM
niki67
May 25, 2010 11:27 AM
ivx675
Mar 27, 2010 01:36 PM
jnduke
Jan 17, 2010 09:47 PM
geoffreyhensley
Sep 10, 2006 03:18 PM
