AC high temperature cycling
Old Aug 29, 2006 | 07:23 PM
geoffreyhensley's Avatar
Default AC high temperature cycling
I have a '97 850 R and at high ambient temperatures, my compressor will cycle off momentarily and then reengage. The problem begins to occur at temperatures in excess of 90 degrees F and worsens as the temperature increases. Strangely, a friend who drives a '94 850 has a simliar problem, but his has degenerated considerably more so that his AC is virtually useless at temperatures above 90 degrees. Help?
Old Aug 29, 2006 | 09:11 PM
Default RE: AC high temperature cycling
Is the Freon level Low?
Old Sep 10, 2006 | 12:53 PM
I've had the coolant checked twice and it's fine. Just for kicks, the mechanic added coolant to it the last time and it continued to cycle like that. I guess it's time to take it to the dealer...
Old Sep 10, 2006 | 03:18 PM
What do the pressures look like?
sghokie
Jul 25, 2011 05:00 AM
Pretorien
Oct 12, 2007 10:58 PM
Nand12
Jun 1, 2006 09:08 PM
frails
May 3, 2006 09:33 PM
scottbr997
Sep 14, 2005 08:57 PM
