How to remove the A Pillar trim to hide a dashcam wire?
Old May 6, 2023 | 10:44 AM
anotherlab's Avatar
Question How to remove the A Pillar trim to hide a dashcam wire?
I have a 2015.5 S60 and I want to run the power cable for a dashcam behind the A pillar trim. I saw references to removing a bolt that is behind the airbag badge. Is that all I need to remove and replace the trim? Anything that has the words "airbag" on it make me very cautious.
Old May 6, 2023 | 02:32 PM
Don't need to take the trim off. Pull seal between the door frame and the door loose - wire fits easily in that gap.
Old May 6, 2023 | 04:29 PM
anotherlab's Avatar
I need to hide it where the wire will come from the dash cam and run along the edge of the windshield. By the time I get to the door, I'm running it toward the back to get to the OBDII port.
Old May 6, 2023 | 11:50 PM
Yes, I have done that many times for a radar detector - tuck the wire under the edge of the headliner, at the top of the a pillar cover tuck it under the edge for the 2 inches the cover is wide, then down the side of the a pillar cover under the rubber weatherstripping around the door opening. Take the cap off the end of the dash - then down to the Obd port.
Old May 7, 2023 | 09:32 PM
anotherlab's Avatar
How does the cap come off at the end of the dash?
jepjrmd
Apr 29, 2015 05:20 AM
ohgodzirra
May 5, 2011 12:23 PM
BHenry
Sep 13, 2010 07:16 PM
Volvo850GLT
Sep 29, 2009 01:50 PM
novablue69
Mar 28, 2006 09:14 PM
