Hum buzz noise coming from radio area.
Old Nov 17, 2015 | 06:45 PM
RjsS60's Avatar
Default Hum buzz noise coming from radio area.
Any help? 2002 s60. A sensor or a fan? Just annoying when listening parked.
Old Nov 17, 2015 | 08:17 PM
pjsmithres's Avatar
I'd listen for the sound and push against the dash on top near the sounds.
Is it all of the time or just AM radio.
Old Nov 18, 2015 | 04:17 PM
RjsS60's Avatar
Default All the time. Dies off about 60 secs after key pulled.
Old Nov 18, 2015 | 04:59 PM
does turning off/on the climate control change anything? Does manually changing the blower speed do anything? does it happen only when the engine is running or can you hear it with the key on position II? It could either be a trim piece resonating with engine vibrations, or the climate control blower or one of the blend door motors.
Old Nov 19, 2015 | 09:54 AM
RjsS60's Avatar
Default At this time nothing affects it. Anytime u can u can power up the radio, ...
...but the radio does not have to be ON.
Old Nov 29, 2015 | 07:54 AM
Bartletts60's Avatar
Funny. I noticed the same on my car. I am also hearing a similar buzzing sound near the ECU TCM box in the front. By removing the relay FMA2 the sound near the TCM goes away. I will check the radio area and see if this is also related.
I am having intermittent electrical problems. Sometimes throws Throttle sensor codes and other problems. Maybe not related.
fourbi4rox
Dec 28, 2012 12:23 PM
bfreilich
Sep 11, 2010 12:33 AM
gillibean
Oct 3, 2008 01:08 PM
ludeless
Aug 28, 2007 07:14 PM
1quikR
Jun 3, 2007 11:00 PM
