Interior Vibrations
Old Nov 24, 2009 | 12:11 PM
capsfan69's Avatar
Default Interior Vibrations
I am new to the S60 world and was wondering where I should start to fix the vibrations I feel when stopped and in gear. If I take the car out of gear (either Neutral or Park) the vibrations are minimal. I took it to the dealer and they replaced the plugs and cleaned the ETM. They also did a "software" upgrade. This did not fix the problem. I really don't want to keep taking it in to have them keep charging me for things that don't fix the problem.
Thanks.
Old Nov 24, 2009 | 01:02 PM
Bender's Avatar
transmission mounts.
Old Nov 28, 2009 | 09:10 PM
capsfan69's Avatar
Are you referring to the lower torque mount or is there a different transmission mount?
Old Nov 30, 2009 | 07:28 AM
RPMCanes's Avatar
I just had my motor mounts replaced under warranty, and that helped a little but I'm going to bring it back while I still have warranty coverage until they cure it.
Old Dec 1, 2009 | 10:55 AM
adub96's Avatar
Need to get your idle adjusted up a bit sounds like.
Old Dec 3, 2009 | 07:45 AM
capsfan69's Avatar
Not the idle....it was just done when they changed the plugs. It is at a constant 700.
Old Jan 5, 2010 | 12:13 PM
RPMCanes's Avatar
I brought mine back for the same issue, and they replaced the steering rack and box, and the other top motor mount they hadn't replaced yet. Moderate improvement but I still feel a considerable vibration in the steering wheel. I would think at this point it would be a pulley or belt tensioner. Thoughts?
S70ismyfriend
Mar 22, 2007 02:00 AM
labsy
Jan 31, 2007 08:40 PM
flamejet
Sep 10, 2006 02:29 AM
Jutboy244
Apr 26, 2006 12:49 AM
BlackDiamondBound
Aug 4, 2005 01:28 AM
