Ipod Adapter
Old Nov 5, 2010 | 06:36 AM
amir11950's Avatar
Default Ipod Adapter
I have a 2006 S60 with the HU-650 sound system. I took my volvo to get the brake vacuum pump changed and I asked the supervisor how much it would cost to get an iPod adapter to be installed, he called me back saying my stereo didn't have the port for them to add the adapter to the back of the stereo. Is this true or did they not even check? Please help. If anyone has any idea of the best way to add an ipod adapter instead of an FM transmitter, please tell me.
Thanks.
Old Nov 5, 2010 | 06:53 PM
S70driver's Avatar
Questions...
- With navigation system?
- Without navigation system, with in dash CD changer?
- Without navigation system, without in dash CD changer?
If you have the Nav system this should work, http://www.crutchfield.com/p_581PA11...ce.html?tp=120
If your without and with an in dash CD changer this should work, http://www.crutchfield.com/p_581PA11...ce.html?tp=120
If your without both this should work, http://www.crutchfield.com/p_581PA11...ce.html?tp=120
Which they all look alike and probably are, seeing as how the links are all the same. Many places sell this kit.
Old Nov 6, 2010 | 02:23 AM
amir11950's Avatar
I have neither navigation or cd changer. But the guy at volvo said my stereo system doesn't have the port it needs to connect to. Does it?
Old Nov 6, 2010 | 01:56 PM
jcoudrain's Avatar
You do have the port. The adapter from IPD uses the CD changer input on the back of the unit. It makes the IPod emulate the CD changer, and even displays the iPod text on the LCD. I got the one at IPD, but I couldn't get it to work without ground noise. It also drained my iPod power like crazy, IPD had no solution and would not refund my money.
There are several options at Crutchfield, including an FM transmitter that connects inline with the FM antenna. This one probably works best.
I plan to run new wires to the speakers from an aftermarket amplifier and connect my IPod directly to the amplifier RCA inputs.
Old Nov 7, 2010 | 11:28 AM
S70driver's Avatar
Sorry but FM Transmitters are a horrible suggestion. While they are the easiest to install and use... They offer the worst possible audio. You have to find a station that doesn't come in clearly to start with and then you have issues with other radio stations bleeding over onto the one your tuned into. Also you have to place the iPod just so, because you will get static.
Also IPD is a good company to deal with and I am very surprised they wouldn't refund your money. Did you talk to a rep from IPD or did you talk to the head man there?
I do see on their site that they don't refund for installed electrical devices, but I am sure if you complained enough they would have.
jigen3
Aug 8, 2011 01:42 PM
jpethan
Mar 16, 2008 01:29 PM
S70driver
Mar 6, 2007 11:47 PM
S70driver
Jul 8, 2006 06:11 PM
AR
Dec 12, 2005 12:31 PM
