Issues with the automatic window regulator
Old Oct 31, 2023 | 03:10 PM
Gillito's Avatar
Default Issues with the automatic window regulator
On my wife's 2008 S60, the automatic window is Not working properly, when the window goes up it doesn't stay closed, it reopens the window unless you hold the button on the up position..
I tried holding the button on the up position as suggested but unfortunately didn't work.. any suggestions?
Thanks in advance!
Old Nov 1, 2023 | 10:26 AM
Sounds like the switch or auto-up/down circuit is not working. Theres some vids on youtube on how to reset the window, check fuses etc that may help.
Old Nov 1, 2023 | 04:11 PM
Gillito's Avatar
Thank you for the tip, the 'remove the fuse while the window is going down' trick did it, now the automatic window switch works as designed, which I am very glad as a new (OEM) switch cost is over $450.. Thanks again!
Gtallard
Nov 10, 2019 09:36 PM
reecesp1eces
Feb 2, 2014 08:44 PM
daver80
Apr 22, 2011 12:13 PM
steved
Dec 20, 2008 05:37 PM
jmaslanka
Nov 27, 2008 07:30 AM
