driver window doesn't roll up all the way
Old Nov 10, 2019 | 10:13 AM
Gtallard's Avatar
Default driver window doesn't roll up all the way
my '90 745 seems to have a misaligned drivers window. I found another forum that suggested replacing the window regulator but the regulator was replaced at 225,000 miles in 2014 (I'm at 251,000 now). if I push up on the bottom of the window, it has no problems rolling up and seating properly. any ideas on how to fix this? thanks
Old Nov 10, 2019 | 06:33 PM
I believe there's a plastic slider that can get gummed up.
sometimes spraying a dry lube, like T.D.L (from the PB Blaster folks) on the groove the window slides it (along the rear edge of the door) can help.
Old Nov 10, 2019 | 09:36 PM
lev's Avatar
lev
Well, normally this is a sign of a worn regulator but if it was replaced then I'd open it up see what's going on. There is some adjustment that can be made.
All power windows, as a general rule, I never cinch all the way up tight--when warm, the parts expand and plastic breaks over time, metal distorts. I leave them slightly, say 1/8 inch, down from the top, avoids premature wear...
bigarms24
Jan 12, 2019 08:06 PM
steelheaddan
Sep 3, 2013 03:47 PM
vollbc74
Feb 9, 2012 07:19 PM
russthomp
Jul 27, 2011 04:04 PM
jay philoon
Dec 30, 2007 10:14 PM
