Leak around timing belt cover
could be the cam seal or the VVT gear/solenoid. Time to pop the covers off and take a look. You don't want to have a wet timing belt. Also, if you find you have leaky cam seals, test for a clogged PCV system. If the crank pressure can't vent via the PCV system, it can push the oil (or seals) out
