Small Oil Leak Inside the Timing Belt Cover
Old Dec 26, 2008 | 01:29 PM
malibu323538's Avatar
Default Small Oil Leak Inside the Timing Belt Cover
I have a small but disturbing oil leak inside from inside the timing belt cover. I haven't looked too closely at where it originates but it seems to be low like around the crankshaft. The car only has 72,000 miles so it seems unusual that seal would be bad. Before I go digging I just want to see if anyone has any ideas if there is some common problem area that might be causing the leak.
Old Dec 26, 2008 | 05:39 PM
Default RE: Small Oil Leak Inside the Timing Belt Cover
Most common problem is cam seals leaking. But it is usually due to clogged vent system.
Old Dec 27, 2008 | 08:03 PM
It sounds like that is worth checking before doing anything else. But I'm really not sure how to do that. Can you point me in the right direction to check for a clogged vent system? Thanks for the response.
Old Dec 28, 2008 | 10:17 AM
What year is it?
Old Dec 28, 2008 | 08:56 PM
It's a 2002 S60 non-turbo. I see where the crankcase ventilation system is but I don't know of a good way of checking to see if it's clogged. It looks like I have to take the inlet manifold off to get to it. Thanks.
Old Dec 28, 2008 | 10:07 PM
Under the manifold on the passenger side is a Bango fitting that screws to the intake. There is a small hose going to it. Check the fitting where the small hose attaches.
brunnmat
Aug 22, 2021 11:34 AM
Robert Burton
Feb 2, 2013 04:51 PM
tscarborough
Sep 27, 2012 05:23 AM
nmikmik
Jun 3, 2012 12:14 PM
huzzsaba
Apr 23, 2007 07:57 PM
