Looking at a 2003 S60 2.5T
Hi,
I’m looking at a 2003 S60 2.5T with 250,000 miles. The car looks really nice and looks like it would be a lot of fun. Is there anything I should be concerned about with this model and mileage? I’ve never previously owned a Volvo.
Thanks
Jason
Thanks
Jason
given the car has had a full life, you need to see what you can learn about its maintenance history. 1) when was the timing belt last done (it should be on its third belt) 2) how's the PCV (glove test at the oil filler?)? 3) what does the transmission fluid look like? (black = bad, brown is ok, red is good) 4) does it consume oil (I'd use a quart per 1000 miles as a benchmark)? 5) has it had a compression test? 6) any smells/drips etc? 7) how does it drive? last question is are you up for doing repairs yourself or do you need a shop for standard maintenance like struts, brakes, oil changes, sensor replacements etc?
As a licensed dealer, you will probably find that the car was well maintained in its life. No matter what you buy or how many miles it has, you will end up doing some repairs. That's cars.
The sales price should not be more than $2500. The only concern that I would have is that the transmission will need replaced soon even if it has had regular maintenance.
I didn't know these had a timing belt until today,is it possible to inspect the belt?
Given the price,if the engine and tranny feel healthy probably going buy it regardless, how else can you get around and have so much fun for 3k?
Are the trannys known to have terminal problems?
Unless it was done at home, there should be some kind of documentation on the timing belt service history.
If you want to inspect it, you'll need to remove the serpentine belt and engine cover to view it. But then again, the timing belt can look good even when it's bad.
Or even more importantly, the idler pulley and tensioner pulley are even more important to inspect since their failures are more likely to cause damage to the belt.
Bottom line... GET THE CAR! You won't find a more car for your money anywhere.
Ahh yes you’re right about the pullies. I had Saab (yeah I said the S word) that kept losing pulley bearings in an unreasonably short amount of time causing full engine rebuilds.
Hopefully that is documented.
Thanks for the info!
Bishop1782
Jul 3, 2014 09:20 PM
malabarka
2001-2013 model year V70
Mar 2, 2014 08:53 PM
