My 2012 S60 T5 - oh oh
Old Jul 16, 2014 | 05:44 PM
  #81
ES6T's Avatar
5th cyl overheat? There is no such thing. Another example of someone ranting about something when they don't know what they are talking about.
Old Jul 18, 2014 | 03:18 PM
  #82
12S60's Avatar
A problem exists with some 2012 S60 FWD transmissions. VCNA acknowledged it and agreed to let me out of a 3-year lease 14 months early. Also gave me a discount on a new 2013 C30.
Some of the loaner S60 vehicles at the dealership exhibited the same problems.
Hopefully, Volvo has corrected the problem.
Old Jul 19, 2014 | 04:02 PM
  #83
Patrick M D'Agostino's Avatar
I'll pull the paperwork & post the EXACT VIDA code later. I'm guessing VCNA has a couple ringers on here. And if it doesn't exist it's because it's been removed with all the "updates" from Volvo. My rant is based on 7 breakdowns from two separate cars. Both of which triggered the initial recall of "fuel pump software" or recall 243 which turned out to be transmissions. Which showed a code in the DIM but never stored in the computer. Only after I recorded the DIM showing the msg while the car "**** the bed" the 7th time did Volvo acknowledge a code. I used to be a diehard Volvo fan. The cars today are not the Volvo's we all knew & loved. They're made in in Sweden & Belgium but a lot of Chinese parts that are Geely sourced. Volvo is hiding a major flaw due to profit. EVER ALMOST GET RUN OVER BY A SEMI BECAUSE YOUR CAR JUST SHUT OFF AT 80mph? Try it seven times & see how you feel. VIDA code to follow smart ***!
Old Jul 19, 2014 | 04:19 PM
  #84
ES6T's Avatar
Recall 243 has nothing to do with transmissions.
Old Jul 19, 2014 | 11:51 PM
  #85
Default VIDA Codes
P030098 Random Misfire Detected - Component Failures - Component or system over temp
P030598 Cyl 5 Misfire Detected - Component or system over temp
Recall 243 is for "Fuel System Software update" It just widens the operating peramiters to compensate for the bad valve bodies inside the Aisin 6sd dual clutch Trans. I had the 1st 2 cars that triggered the recall. The second car has a new Trans. Only after I filmed the code showing in the DIM. Codes show in the DIM but don't get stored. The "update/recall" is to cover the bad Trans in cars. What more expensive? A recall with software updates or replacing transmissions?
Old Jul 20, 2014 | 03:02 AM
  #86
12S60's Avatar
I had a 2005 Audi A4 with a CVT transmission. Although I never had a problem with it, VW notified me in 2013 that a class action lawsuit settlement had been reached regarding the Audi CVT transmission. VW offered reimbursement for previous repairs, an extended transmission warranty and if I remember correctly, compensation for trade-in value losses.
Hope Volvo does the same.
Old Jul 20, 2014 | 08:41 AM
  #87
ES6T's Avatar
So there was a misfire in cylinder 5. Not a transmission issue at all.
Recall 243:
Volvo has identified that fuel may not be transferred from the passive to the active part of the fuel tank. Under certain driving conditions, the driver may notice engine hesitation and in a worst case scenario the engine may stall, even with the fuel gauge indicating up to ¼ of fuel remaining in the tank.
The corrective action is to perform an Engine Control Module (ECM) software upgrade per TJ# 24855.
This recall affects 7,555 vehicles in the U.S., 402 in Canada and 3 in Puerto Rico.
So nothing to do with the transmission.
Old Jul 20, 2014 | 12:56 PM
  #88
12S60's Avatar
Because of a continuing problems with the 6-speed automatic transmission, Volvo offered to take back my 2012 S60 T5 FWD and give me a discount on a 2013. Funny, but on the 2013 S60 test drive the salesperson said, "And for 2013, the transmission has been much improved."
I opted for a 2013 C30 with the older 5-speed automatic.
Old Jul 20, 2014 | 01:02 PM
  #89
ES6T's Avatar
Cool. Volvo always keeps the sales people in the loop on technical issues and changes. I would totally trust anything a sales person says.
Old Jul 20, 2014 | 01:59 PM
  #90
12S60's Avatar
I took the salesperson's comment to mean that Volvo acknowledged there was a driveability problem with some 2012 S60 T5 FWD 6-speed transmissions. So after 22 months of problems with the 6-speed, I chose the older "tried and true" 5-speed.
Old Aug 13, 2014 | 07:16 PM
  #91
Ride S40T's Avatar
Patrick, did your service team ever find out why #5 had the misfires?
Mine's done this 3 separate times. Once last July, once this April and once this July. All three during rainstorms. 3 engine lights, 3 identical codes, 3 identical driving situations.
They've swapped coils, sprayed the engine with water, replaced plugs, dropped the fuel tank to check for crud all to no avail.
brent@fluidequipment.com
Aug 17, 2014 12:32 PM
dantheman7
Jun 7, 2011 07:07 PM
heyhelm
Jun 6, 2011 08:01 PM
lfiffik
Apr 2, 2011 04:27 PM
chicagopete
Mar 31, 2011 07:40 PM
