My problem
Old Mar 29, 2012 | 12:29 PM
FlRandy65's Avatar
Default My problem
I have a 2003 S-60, Non-turbo,2.4L engine. It has started to make a whistling noise when it runs. There is a strong vacuum in the crankcase. When running you have to pry the oil filler cap off. The noise stops then. Just found out that I can make it stop by lifting the dipstick as well. Any help in this would be greatly appreciated.
Old Mar 29, 2012 | 01:35 PM
J. A. Higgins's Avatar
How long since the engine air filter was changed? Is the filter installed properly?
Old Mar 29, 2012 | 05:31 PM
Mad Matt's Avatar
Sounds like your PCV (positive crankcase ventilation) system is clogged.
Old Mar 30, 2012 | 07:19 PM
FlRandy65's Avatar
Thank you both for your answers. Yes the air filter is in properly. And has been changed. I fear it is the pcv system. The noise seems to come from that location. I just cant get it off without takeing off the intake manifold. I was hoping for a quick and easy solution. Again thank you both. Randy.
s70_t5_1999
Jan 22, 2010 11:53 PM
chimmychong
Apr 24, 2008 01:59 PM
volvo_s70
Jan 22, 2008 01:19 PM
toshields
Dec 8, 2007 04:50 PM
