problem after problem
Old Oct 30, 2007 | 08:40 PM
chimmychong's Avatar
Default problem after problem
k so ive fixed so many problems in my 2001 s40... and ive come across another problem ... my gas gauge is kinda stuck on empty even though i put 20 in the tank about 30 mins ago... this has happened before but it was stuck at 1/2 full when i filled my tank up... and the gauge started to move after i drove half of my tank.....
but yea anyways i had about 4 gallons in my s40 and my gauge was working but i turned my car off to wait for someone and when i turned it back on my passenger noticed my gas was on empty ... but that is inpossible cause i looked at it right before i turned my car off.... how would i fix this problem & how much would it cost?????
o and my 2001 s40 doesnt like to start first try ONLY after i pump gas but it starts up the 2nd try....
Old Oct 30, 2007 | 09:31 PM
Default RE: problem after problem
Sounds like you have a couple of problems.
1.The fuel guage might need the software download from the Dealer to calibrate it.
2.The long crank time could be many things. The first thing I would check is the fuel pressure regulator. It is mounted on the end of the fuel rail. pull the hose off the intake side at the vaccum port. I will bet a small amount of fuel comes out of it.
If it does the regulator is bad.
Old Oct 30, 2007 | 09:57 PM
Hudini's Avatar
Gas gauge I cannot help you.
The long start I fixed today with a $105 fuel pressure regulator. The funny thing is as I was pulling off the vacuum hose for the FPR, I noticed it was cracked about halfway through. So, was it the cracked rubber hose or the FPR itself? IDK as I don't want to mess with a good thing. Check your vacuum hoses before spending good money. The S shaped hose off the FPR is the first one to check.
Old Oct 30, 2007 | 10:21 PM
Volvocars's Avatar
Like tech said the regulator is most likely leaking and its an easy check.
As for the gauge I would be more likely to check the tank pump/sending unit itself. I do think an upgrade will help this (or is available). I could be wrong.
Old Apr 24, 2008 | 12:12 PM
ok so i replaced both coils , new radiator hose, new coolant temp sensor, new spark plugs over some time..I still have some starting problems and airbag light is on also i have to put in coolant every now and then
my car doesnt like to start after i get gas ( only after i get gas ) the first time i crank it the car feels like it shakes then dies ... then the second time it always turns over but i have to crank it for like 4 seconds??
I just replaced my FPR and went to go get gas and the problem is still there
Old Apr 24, 2008 | 01:59 PM
djerikd's Avatar
You shouldn't have to replace coolant. You need to figure out where the coolant is going. Does your windshield fog up and have a sweet smell in the car? That'd be a leaky heater core ($400 parts + 6 hours labor). Coolant in oil? Oil in Coolant? Could be head gasket or bad radiator.
Dont overfill the fuel tank. I remember hearing some stories about topping off the tank leading to some emissions system problems.
spunkymonky
Nov 18, 2008 08:50 PM
Bonkajs
Jun 18, 2008 03:47 PM
casique
Oct 20, 2006 03:31 PM
Red XC
May 9, 2006 12:07 AM
billp46
May 5, 2006 09:13 PM
