my transmission stops when warm
Old Jun 17, 2018 | 01:24 PM
dieter's Avatar
Default my transmission stops when warm
Volvo S60 2.4T 2002
When the transmission get just a little warm it stops; after a wait it it will move a very short time. Why?
Is there a on board computer tho diagnose the problem?
Old Jun 17, 2018 | 02:31 PM
have you checked the fluid level and color? Yes the transmission computer will set fault codes for specific conditions. You may also want to try the "shifter row" in case its actually the PNP sensor acting up.
Old Jun 25, 2018 | 08:05 AM
pierremcalpine's Avatar
Agreed, fluid level and colour first being sure to check fluid level after driving for a good 20min (i.e. when temp has reached the prescribed 80deg).
Would be very helpful to hook up VIDA to get some live readings on what temp the fluid reaches as you go through the shut-down experience.
Old Jun 25, 2018 | 01:08 PM
tony1963's Avatar
Sounds like a solenoid problem to me. When the transmission heats up, the ohms in the coil of the solenoid probably are too great to work properly.
Has the transmission been shifting harshly before this failure?
herbls
May 20, 2018 04:49 PM
LAS60
Nov 8, 2011 07:36 PM
magmagnus
Jun 11, 2009 04:04 PM
mason3325
Sep 22, 2008 01:22 PM
yineyes
Jul 11, 2007 11:35 AM
