Noise (Clunking) in the rear
Old Mar 26, 2008 | 07:47 AM
leebae's Avatar
Default Noise (Clunking) in the rear
I am experiencing a clunking noise in the rear of my '02 S60. The noise appears to be coming from the rear wheel area on the driver's side. The noise is most predominant over bumps. It can still be heard during normal driving as well. I had the vehicle checked. I was advised that the shocks and struts did not show any signs of damage. No leaking etc... They thought the noisemight beloose cargo in the truck. I have removed everything from the truck. That was not it. I even re-secured the plastic cover over the battery. I really believe the noise is coming from the wheel area.
ANY IDEAS ????
Old Mar 26, 2008 | 12:59 PM
twowheelin's Avatar
Default RE: Noise (Clunking) in the rear
Did you check the spare and jack/tools? My jack is held with a velcro strap that seems like it could loosen and let that stuff bounce around. Other than that, I guess I would get the rear end up on stands and check the sway bar links and other suspension linkage....
Old Mar 26, 2008 | 01:06 PM
NemesisT5's Avatar
Check your rear drop links for play..
Old Mar 26, 2008 | 06:59 PM
Rear sway bar links.
redvv07
Jul 30, 2009 11:06 PM
brians46236
Sep 24, 2008 10:11 AM
ice queen
Jan 16, 2008 02:58 PM
m1964
Feb 3, 2006 12:32 AM
Red XC
Suspension
Oct 22, 2005 11:58 AM
