noise under dashboard
Old May 6, 2012 | 08:02 AM
wmlbiz's Avatar
Default noise under dashboard
I have a 06 s60,70kmiles,2.5t. I am getting this noise that sounds like it is coming from under the dash on the passenger side. It's hard to describe, but it sounds like a small motor or pump turning on and off. It also seems to do this mostly when the engine is still cold. The dealer says that it is supposed to do that, and it is related to the ABS system. Is that true? Any thoughts?
Also, there is a broken hose that I think is called the turbo intake hose. I'm wondering if the two things are related.
Old May 14, 2012 | 01:28 PM
TrekOn's Avatar
I have the same problem - sounds like something scraping/scratching. Mine's a 2004 S80, recently acquired.
Old May 14, 2012 | 02:59 PM
J. A. Higgins's Avatar
When the car is stated and moves approximately 100 feet the ABS does a system check that sounds like a scrape, that part of what the dealer said is true.
If you have a broken turbo intake pipe, that can emit a variety of sounds and not very good on the engine.
Old May 21, 2012 | 08:46 AM
wmlbiz's Avatar
Default possibly related?
I recently posted a photo of a broken hose, not knowing what it was. Could this be the turbo intake pipe?
Old May 23, 2012 | 03:06 PM
TrekOn's Avatar
Had it checked by a Volvo specialist. He said the noise is from worn out motors that adjust the air vents.
thegazelle
Jul 23, 2014 05:19 AM
duikboot
Nov 4, 2011 01:18 PM
trosaire
Aug 19, 2009 08:05 PM
superbeetlejosh
Oct 27, 2008 04:07 PM
