Noisy front suspension
Old Apr 23, 2008 | 11:39 AM
grease monkey's Avatar
Default Noisy front suspension
I have been asked to look at my uncle's '03 S60 D5 80,000 miles, which has a noisy suspension, on the l/h side.
I have replaced the drop links, the lower ball joint and both wish-bone bushes.
The noise still persists, it sounds worse over uneven road surfaces rather than speed bumps.
It sounds more of a rattle, that of locking wheel nut covers or brake pads rattling. I have checked these, all ok.
All I can think of, is the actual strut unit or spring seats.
Any help would be welcomed
I dont not have access to his car all the time, so I may be tardy in replying.
Cheers
gm
Old Apr 23, 2008 | 12:29 PM
hudsonriverS60's Avatar
Default RE: Noisy front suspension
I have some noise as well. Maybe not what you are experiencing. But I am 99.9% sure that in my case the strut spring is hitting the inside fender wall under certian conditions.
Old Apr 23, 2008 | 06:21 PM
Usually it is a bad upper spring seat.
Old Apr 24, 2008 | 07:09 AM
ORIGINAL: tech
Thanks, Is there any way of checking this without dismantaling the leg?
gm
Old Apr 25, 2008 | 06:23 PM
Yes if you can turn the top strut nut they are bad.
If it feels rubbery they are good.
tomecsi
Apr 24, 2012 09:37 AM
spankey
Jun 25, 2009 06:53 PM
spinningcain
Feb 2, 2006 01:17 PM
meerkat
Aug 16, 2005 01:07 AM
05s40
Mar 10, 2005 11:40 AM
