Noob with a headlight question
Old Oct 9, 2006 | 10:25 PM
us11186's Avatar
Default Noob with a headlight question
Low beam error message came up this morning. I changed the bulb and checked the fuse and the light still does not come on. Is there something I missed?
2002 S-60 T5 Silver if that matters.
Thank you for any help you can give.
Old Oct 9, 2006 | 11:59 PM
Default RE: Noob with a headlight question
Check the wiring at the Headligth bulb.
Old Oct 11, 2006 | 05:50 PM
adub96's Avatar
had same problem with turn signal bulbs ended up cleaning the connectiona nd using dielectic grease, never came back after that.
Old Oct 17, 2006 | 12:26 AM
us11186's Avatar
Well I swapped bulbs and cleaned and look around. Nothing. Now the hi-beams will not stay on after a while. I'm going to the dealer to have it looked at. When I get an answer, and prove that it works, I'll post it. Hopefully this will help anyone else that has had the issue. I do feel bad knowing I tossed I good bulb.
Turconator
Sep 26, 2008 06:33 PM
Hondu5
Nov 12, 2007 05:06 PM
FarCanal
Aug 2, 2007 03:19 AM
2002S80T6
Jul 22, 2007 10:33 AM
dano7331
Apr 23, 2007 11:50 AM
