More Problems...
Old Oct 11, 2006 | 10:07 PM
MK1's Avatar
MK1
Default More Problems...
Anyone care to take a stab at this one:
Whenever I let off of the accelerator, I get the most aweful "grinding" sound coming from the right front of the car. It does not happen while I am giving it gas. This just started yesterday.
Will I need to go to the credit union for a loan on this one?
Old Oct 11, 2006 | 10:12 PM
Default RE: More Problems...
Do you notice anyother things at the same time?
Old Oct 11, 2006 | 10:15 PM
MK1's Avatar
MK1
Thanks for the quick reply.
Don't really notice anything else. However, the front tires are "cupped" fairly bad and have been that way for a little while. Other than that, nothing else.
Old Oct 11, 2006 | 10:17 PM
MK1's Avatar
MK1
Forgot to add...car has 99k on it.
Old Oct 11, 2006 | 10:25 PM
See if the upper torque mount is almost gone. They dryrott then fall apart.
Old Oct 11, 2006 | 10:31 PM
MK1's Avatar
MK1
The torque mount appears to be a little bit loose. I think that one of the mounts has been replaced...one of them looks blue, the other is white.
Old Oct 11, 2006 | 10:34 PM
If they are blue and white then they are not factory?
Old Oct 11, 2006 | 10:37 PM
MK1's Avatar
MK1
I guess not, the bushings definately are a different color on each side.
Would this have an affect on the grinding sound that I am hearing?
Old Oct 11, 2006 | 10:43 PM
Maybe they are urethane.
Might also have another one bad so that when you let off the gas you feel the motor torquing from slowing down.
Old Oct 11, 2006 | 10:45 PM
MK1's Avatar
MK1
I see...
Any chance it could be a bearing or a drive shaft?
Old Oct 12, 2006 | 02:18 PM
MK1's Avatar
MK1
Just found out...its a bum axle. 862 bucks...ouch.
Old Oct 12, 2006 | 09:07 PM
I feel your pain.
Old Oct 13, 2006 | 07:45 PM
Volvo2001's Avatar
Is that dealer cost for repair and parts?
If you are not mechanically challenged, then it would be cheaper for you to buy the part and do it yourself. [8D]
Old Oct 13, 2006 | 08:19 PM
MK1's Avatar
MK1
862 was dealer cost. However, I found an independant mechanic to do it for 560...450 or so for the part + 110 to put it in. Either way, it is a bummer. Blowing out an axle at 99k miles on a 30+K vehicle...yikes. I think I could have better luck mechanically with a Kia. Life with the old Volvo is starting to get a bit costly!!!
Old Oct 16, 2006 | 07:10 PM
MK1's Avatar
MK1
Update:
Mechanic put in a rebuilt one for 99 bucks plus labor...214 total. Now that I can handle.
Old Oct 17, 2006 | 01:13 AM
Volvo2001's Avatar
ORIGINAL: MK1
Update:
[sm=icon_rock.gif] Great. Always good to save some green stuff.
akabond
May 28, 2011 08:17 PM
gordon368
Jun 6, 2009 03:01 AM
flamejet
Sep 9, 2006 02:48 AM
nick54
Apr 24, 2006 12:37 AM
