Oil additives for 2.5 5 cyl turbo
Hey folks,
I'm a relatively new owner of a 2015 S60 with the 2.5 5 cylinder turbo. I recently did an oil change using 5W30 Liqui Moly synthetic. I am aware that Volvo does not recommend any additives (probably because there is a lot of "overhaul in a bottle" junk out there lol), but what about reputable additives like Lucas and Marvel Mystery Oil? Are they good, bad, and/or worthless? The car has 74,000 miles.
I agree with hoonk. I have used liquimoly's ceratec on my old P2 S60 after an engine flush due to poor previous maintenance, but once I read in the new car's manual not to use any additives, that's all I needed to not add anything to my newer car.
Did the ceratec additive do anything? No clue. Does it feel like it did anything? Not at all.
I did notice my gas mileage improve, but I did a lot of things to my car that could have potentially increased that and it would be incorrect to assume it was any one thing I did.
I do vouch for the engine flush they have though. It really helped clean all the gunk out from lack of good maintenance practices.
+2 On a recent generation car running full synthetic - My two cents on oil additives are simply a "don't". Just change your oil on schedule with a quality full synthetic brand (I use Castrol Edge which you can buy at Walmart) in the correct weight and spec and your engine will last 300k+ miles. I'd also suggest buy OEM quality filters (I use Mann who I believe is Volvo's OEM supplier) as those double/micro blah blah blah filters can actually do more harm than good by restricting flow and lowering oil pressure.
What's in MMO? See this thread.
https://bobistheoilguy.com/forums/th...ry-oil.320686/
