Opinions Please
Old Oct 7, 2008 | 09:26 AM
sas80's Avatar
Default Opinions Please
Asking this question makes me nervous. I feel like I should knock on some serious wood...
<exhale> here goes.....
I have an '01 s60 non turbo with 62k miles on it. I am an avid, responsible, oil changer. Every 5-7k miles, without fail.
When the "Time for Service" Light comes on, I invoke the pattern, turn the key and press the odometer **** till it goes away.
I did have the front brake pads changed once. Other than that, and oil changes, and the fuel pump recall, I have never had any service done to the car. I have never needed to, nothing has ever gone wrong.
I will be taking the car into Volvo to get a luggage rack installed when I need another oil change. This is my attempt at not having to purchase an SUV.
I am wondering if there are any services that anyone would highly recommend I get done to my vehicle. Is it safe to "leave well enough alone"? Or am I really just setting myself up for a larger failure down the line.
Any opinions are appreciated.
Thanks
Old Oct 7, 2008 | 11:45 AM
Default RE: Opinions Please
I would do the 60K service. It is the major tune up service.
Old Oct 7, 2008 | 11:53 AM
sas80's Avatar
Would you mind telling me exactly what is involved in the 60k tune up?
I'm hoping it's NOT a lot of "inspecting this" and "topping off that" type of situation....
Old Oct 7, 2008 | 12:01 PM
Spark plug,Air filter,Fuel filter,oil change then the normal looking the car over. Some also replace the cabin filter.
Old Oct 7, 2008 | 04:17 PM
sas80's Avatar
okay, please tell me why, besides the fuel filter, I cant just do all this myself.....
They are going to want a fair amount of $$ to simply drop a bunch of new filters/plugs into the car.
Plus, having my fuel pump replaced recently, under the recall notice, didn't they change my fuel filter then?
thanks
Old Oct 7, 2008 | 04:38 PM
No they would not have changed the filter.
You can do it all yourself. Most Dealers will want over $600.00 for the service.
Go to FCP Groton and buy it all and install yourself.
Old Oct 8, 2008 | 05:17 AM
las4444's Avatar
For my 60K service they also flushed the brake and cooling fluid. I also have an AWD so they adjusted it components also. It ran me $600 as mentioned. You should change the brake fluid. I had a 940T that starting having brake pistons stick at 8 years old.
Skiesthelimit187
Aug 20, 2007 05:40 PM
fairchance
Nov 1, 2006 12:27 PM
volvoai
May 4, 2006 10:30 AM
Stefan
Mar 2, 2006 02:24 PM
volvobacon
Dec 13, 2005 12:44 PM
